Not enough memory?
11152
8
12-15-2015 03:11 PM
CarlosHernandez8
I have Windows 8.1, I tested with 10.2.2 and 10.3 ArcMap I'm exporting to PDF and get the error after a while "not enough memory" ah! I have 16gb of ram and you increase virtual memory, clean, defragment the disk ... etc .... I had never happened ... someone can help me ....... Greetings.
JoshuaBixby
MVP Esteemed Contributor
It is always helpful to post specific error messages, either the code and result if scripting or a screenshot in using the GUI.  That said, ArcGIS for Desktop is a 32-bit application so it has some memory limitations regardless of how much memory the operating system is running.  If you run task manager and watch the memory usage, how high is it getting before getting the error message?
DanPatterson_Retired
have you installed ArcGIS Pro? and tried it there?
Addendum....
it is 64 bit, ergo...not as limited memory-wise
DEAF_PROBERT_68
Honored Contributor
Use OneNote and it has "Take screen clippings" and the paste to OneNote and save it as png file..
JoeBorgione
At my age I can totally identify with not enough memory...
Wait.  What were we discussing?
That should just about do it....
I added an addendum Joe...I knew I had a point in my original post...but it is hard to keep focused some days isn't it
DanEvans
DanEvans
Also, there are some setting in the AdvancedArcMapSettings utility, found in: C:\Program Files (x86)\ArcGIS\Desktop10.2\Utilities (or similar depending on OS and version):
MichaelVolz
This thread is old and the Article only goes up to 10.3.1, but I am encountering this issue in 10.5.1.  Has anyone encountered this exporting/printing issue in 10.5.1?
Does anyone know what specifically fixed the issue for them in previous versions of ArcMap?
