Not able to view full comments in the table
2001
11-16-2017 07:31 AM
KyleMcGilberry
I am not able to view full comments in the table but am whenever I identify a feature in the identify window. It is not due to the length of characters.
RobertScheitlin__GISP
Kyle,
   Is there a line return/carriage return after the "Connections Changed" portion of the string?
Kyle,
   When the comment was entered was a line return (i.e. Enter key pressed) after the "Connections Changed" portion of the string?
KyleMcGilberry
Unfortunately I was not the one who created the comment so that could be the case. The vendor could have done that to possibly clean up the comment section but I would like to have that information in my table. Is there anything to be done on my end that could make this possible?
DanPatterson_Retired
I would experiment on a sample and use a python expression emulating the following
a = "a line \n with another line"
print(a)
a line
 with another line
b = a.replace("\\","")
print(b)
a line
 with another line
this could be done in the field calculator as a simple expression with the python parser
!YourField!.replace("\\", "")
did I mention a sample, test file
AbdullahAnter
Honored Contributor
Yes, Robert  I think that is the reason.
