NoData issues with Geotiff
2572
06-20-2012 03:59 PM
JasonAdelaars
Hey there,
So I exported a geotiff from MatLab and imported it into Arc10. The cells and values are exactly where they're supposed to be, however the cells with NoData are displaying the color of the minimum value in the color ramp. Setting the NoData values to No Color in the symbology properties does not work. Any ideas??
Jason
AlfredWagtendonk
This is a recurring question for which I give you my recurring answer:
I had a similar problem and first tried to convert my data as well. But, than noticed my Geotiff had a compression applied ('PACKBITS'). After exporting my dataset (right click layer =>Export Data) to an uncompressed Tiff (Compression type: NONE), the problem was solved: NoData cells behave again like expected and you can carry out again common NoData operations. So have a look at your layer properties to see if your Tiff has been compressed as well and if so uncompress it.
Good luck and best wishes,
Alfred Wagtendonk
