network i/o error dbms
5402
11
05-27-2013 12:30 AM
tamerali
plz i need u help , i have sde geodatabse for oracle , but i have problem in it , it containing 4 feature classes ,
it works good , but when i am add one of them (gis _trade feature class) , error occurred  when i zooming it or any thing
,other feature classes is ok , but when im add this layer  , they too have the same problem
the selected object failed to draw , network i/o error
i am sorry for my bad english
arcgis 9.3
arcsde 9.3
oracle 10g
VinceAngelo
Esri Esteemed Contributor
If you had mentioned points in any of your previous posts, or had provided the
'sdelayer -o describe_long' output when requested, or had reported the output
of 'sdelayer -o feature_info' we would have been better able to help.
At this point, you'll probably be better off using Tech Support, since you're
dealing with configuration and/or corruption issues that are not easily solved
via these Forums.
Good luck.
- V
tamerali
Layer Configuration ..: DEFAULTS
Layer Description ....: <None>
Table Owner ..........: PROJECT
Table Name ...........: GIS_TRADE
Spatial Column .......: SHAPE
Layer Id .............: 21
SRID .................: 1
Minimum Shape Id .....: 1
Offset ...............:
  falsex:   -5120900.000000
  falsey:   -9998100.000000
System Units .........:      10000.000000
Z Offset..............:          0.000000
Z Units ..............:          1.000000
Measure Offset .......: <None>
Measure Units ........: <None>
XY Cluster Tolerance .:          0.001
Spatial Index ........:
  parameter:    SPIDX_RTREE
  exist:        Yes
  array form:   -2,0,0
Layer Envelope .......:
  minx:    357656.20280,        miny:   2888018.48770
  maxx:    372293.78830,        maxy:   2897430.10350
Entities .............: npc
Layer Type ...........: In-Line Spatial Type
Creation Date ........: 08/18/13 14:36:08
I/O Mode .............: NORMAL
Autolocking ..........: Enabled
Precision.............: High
User Privileges ......: SELECT, UPDATE, INSERT, DELETE
Coordinate System ....: PROJCS["WGS_1984_UTM_Zone_38N",GEOGCS["GCS_WGS_1984",DAT
UM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich"
,0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAM
ETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Centra
l_Meridian",45.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin
",0.0],UNIT["Meter",1.0]]
