Need to convert raster elevation data to polygons
2746
04-14-2013 09:42 AM
BradleySmith2
I have a data set that I downloaded from the national elevation data set (NED).  The data is for a river meander reach.  Is there a way that I can convert the raster data to polygons, consistent with the way in which I have symbolized the data in the attached example?  The data is symbolized based on elevation ranges (z values) shown in the dialogue box.
[ATTACH=CONFIG]23477[/ATTACH]
EricRice
Esri Alum
Reclassify comes first since it will result in an integer raster, then convert to polygons.  You can't convert floating point rasters into polygons.
Best,
Eric
MarkChilcott
You probably need to do a Polygon to Raster:
http://resources.arcgis.com/en/help/main/10.1/index.html#//001200000030000000
Followed by a Reclass:
http://resources.arcgis.com/en/help/main/10.1/index.html#//009z000000sr000000
Licensing would require Spatial Analyst or 3D Analyst.
EricRice
Esri Alum
Best,
Eric
