My "Ok" button is grayed out
6268
10-09-2011 12:48 AM
BrittanyShapiro
I'm trying to geocode using one of Arc Map 10's default address locators.  When I try to initiate the geocoding process on the next window, I can't, because the "OK" button is grayed out.  I've matched up all the address input fields; I can't figure out why this is happening.  Any ideas?
GarethMann
I am having the exact same problem. Did you work out how to fix it yet?
GarethMann
Opps, I feel pretty silly replying a couple minutes after asking, but for me it was simply a matter of changing the default location for where to save the output. I created a new directory called "C:\temp\" and saved my geocode ouput as a standalone shapefile to there and then I was able to press the "OK" button.
No idea why the default location that they provide does not work. ESRIIIIIIIIIII..........
AnthonyTrilsbach
How do you change the default location for the output please?
JoeBorgione
See attached image; navigate your way to what ever output location you want.  Personally, I don't like to write to shapefiles, I like geodatabase feature classes.
Hope this helps-
That should just about do it....
MaximSilin
... it was simply a matter of changing the default location for where to save the output.
Changing the geocoding output path worked for me as well.
