Multiple Geodatabase At Oracle
3496
6
07-22-2010 01:21 AM
YudiArdianto
Some one can help me...
I just create a multiple geodatabase at oracle at same SID (ex:ORCL) as usual there is one SDE schema at ORCL, it is possible to create more than one SDE schema at same ORCL ? cause iwant to create replica at the same ORCL
Regards
Yoe
VinceAngelo
Esri Esteemed Contributor
No, this is not possible.  Multiple repositories require muliple Oracle instances.
- V
YudiArdianto
- V
Dear Mr.Vangelo
Thanks for your answer, i'm just curious about that matter because i have limited orale license to create another instance, or there are another solution to replica geodatabase at one instance.
Yoe
VinceAngelo
Creating two replicas in one database instance would be possible with any of the
other DBMSes supported with ArcSDE, but Oracle uses a differrent container model
and cannot be used in this manner.  If cost is the issue, you should look at using
open-source PostgreSQL instead.
- V
OvidioRivero
I don't know if you are still watching this thread but you could create a schema geodatabase. This is supported in Oracle.  That puts another SDE schema on the database and you can create whole other arcsde GDB.
Take a look at this.
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Using_multiple_geodatabases_within_a_D...
VinceAngelo
User schema geodatabases do not create another SDE schema.  They create parallel ArcSDE tables
in a different schema, which work in concert with (but apart from) the existing SDE schema's tables.
- V
YudiArdianto
Hi all
Thanks for the answer and solution, i will consider to use PostgreSQL to make replication or another DBMS to create a replication.
Regards
Yudi
