Multi-Band Image Raster to ASCII file
2939
06-18-2013 10:12 AM
CatherineFinkenbiner
Please help,
I have uploaded multi-band Quickbird satellite image files into ArcGIS 10.1. Each layer has 4 bands (Red, Green, Blue, and Near-Infrared). I have created a false color composite of each satellite image (Band 1- NIR, Band 2- Red, Band 3- Green).
In order to analyze the variability of colors across the landscape, I hope to transform my ArcGIS layers into ASCII files displaying each of the colors as a number.
I have tried using the Raster to ASCII tool and a single text file is produced. I do not understand where the numbers in this text file are coming from or what the number values represent. I think each Band should be a separate ASCII file (one ASCII file for Band 1, one for Band 2, one for Band 3), I am just unsure how to convert a single band from a multi-band raster image into an ASCII text file.
If it is not possible to convert each band individually into an ASCII file, is their a way to combine all three color values into a single unique index?
Thank you,
Catie
curtvprice
The tool used the first band of the multiband raster.
You can access other bands by navigating into the multi-band raster in the Add Data dialog to select one of the bands. The exact path syntax used to access the individual bands depends on the raster data format.
Thank you!
