Mosaic raster dataset
4446
11
01-25-2019 01:42 PM
EmmanuelOkoro
Hello, I'm trying to mosaic 100+ raster dataset using the Mosaic to new raster tool, but it's taking for ever to complete. Its been over 30 hours and still running. Is there a faster or better way of doing this?
- Emma
EmmanuelOkoro
Am not sure which one of the above. I used 'Generate Tile Cache Tiling Scheme' tool. also tried using the cache option when Publishing it online. I'm not sure if that was the best and most efficient way to do it. It took over 24 hours and way too much server space.
MichaelVolz
Esteemed Contributor
I would suggest only caching some of the smaller scales (less tiles) and see how that works in the image service.
I would definitely find out if you are using compact cache or not as that is the more efficient cache format.
