Mosaic HDF land cover data from MODIS
3130
07-12-2012 12:19 AM
LuisCosta
Dear all.
I hope this is the correct section to pose my problem..
I have downloaded the complete data set of MODIS land cover in HDF format.
I want to combine all the tiles in one large and for that I have used the Mosaic to raster tool under arcmap 10.
To facilitate the process I have divided the data into 10 parts and runned mosaic to new raster is all of them. Everything worked fine until I reached Europe. The HDF tiles from the 17 and 18 columns simply do not get together. The final product of the mosaic to new raster tool is a empty raster...
I tried some things like converting HDF to TIFF and GRID formats but the problem persists with the same empty raster outcome.
I have not changed any of the environments setting for I'm not such experienced user...
Any help on this would be highly welcome..
Thanks in advance and all the best!
ChrisBater
As this is an esri forum this may not be terribly helpful, but if you have access to envi/idl you should check out the modis conversion toolkit, which you can find here:
http://www.exelisvis.com/UserCommunity/CodeLibrary.aspx
Chris
