Mosaic Dataset problems creating seamline
3100
02-22-2016 05:37 PM
ADREETATHAKUR
Hello,
I am trying to mosaic 250 tiles with colour balancing to create a seamless mosaic. I am having issues generating seamlines for the mosaic.
Seamlines are not generated for all the images. If less than 50 image tiles are used to generate seamlines and colour balance; the output produces a perfect seamless mosaic. Only when I add more than fifty images, seamlines for a few random image tiles are not generated. I have changed the "Maximum number of Rasters per Mosaic" to fit the numbers images I am working with.
Same issue with colour balancing - less than fifty images produces excellent result, but more than around fifty images will not generate a colour balanced image. I have build pyramids and statistics for the dataset before doing colour balancing.
I am using ArcGIS 10.3
Thanks in advance for any help and suggestion
Adreeta
DanPatterson_Retired
given the specifications here Create Mosaic Dataset—Help | ArcGIS for Desktop
what options were used?
are all the images the same type (exactly)
and in here Add Rasters To Mosaic Dataset—Help | ArcGIS for Desktop
what options were used, and were all the data source compliant with the options
