Mosaic Dataset - Displays Perfect in ArcMap, but not as an Image Service
2165
10
03-29-2011 11:14 AM
LukePecoraro
I am currently testing creating a mosaic dataset out counties most recent aerial imagery.  I have a small mosaic dataset all set up with overviews which displays perfectly in ArcMap.  I can zoom through from 500,000 all the way in and can always see the imagery.  It has no trouble displaying both the overviews and the source images.  When I publish this out as an image service, and drop in it ArcMap, the overviews display fine, but once I zoom past 3,500, (I assume when it switches to the source imagery) all I see is monotone gray or blue (slightly different color for each tile).  This sounds like a statistics issue, but I created two identical mosaic datasets, one with statistics calculated on the dataset and one without, served them up and I see no difference.  Also if it were statistics, shouldn't ArcMap be doing the same thing?  I do have statistics calculated on the source images.  Any suggestions or ideas would be greatly appreciated.  Thanks.
BillBean
We should have used the UNC path...instead we were using the drive letter....this fixed it for us.
