Mosaic Dataset Color Correction Problems
1212
02-16-2010 07:18 AM
DavidGreene
I've created a Mosaic Dataset for which I manually adjusted the histogram settings for one of the rasters to generally match the color other.  Then I found out about the Color Correction tab.  It corrected the color better than I had manually set.
The problem is that hitting the "Correct Color" button only works once.  After that, the mosaic preview disappears and shows all white .  The only way to get it back is to turn off the "Apply Color Correction" in the Mosaic Properties -> Defaults tab .. that process gets annoying when experimenting with the various settings.
The other problem is that when I Build Overviews with the color correction applied, the overviews are solid black.  This doesn't happend with the color correction off.
HongXu
by Esri Contributor
This is a known issue in beta 2. It will be fixed in pre-release.
Hong Xu
Raster team, ESRI
