Migrate an existing SQL Server Database to be an ArcGis geodatabase
794
10-23-2011 09:27 AM
AlaeddineSaadaoui
Hi all,
I have an Sql Server Database that contain some tables with GPS positions. When I started using arcgis the last summer, I used ArcCatalog to register the tables with Geodatabase and a new field called OBJECTID was created to be used as an id by ArcGis. The problem is that I already have primary and foreign keys and the database is also used by other applications. So I am wondering how I should work with the new OBJECTID field if I don't want to change my primary and foreign keys. And could I change OBJECTID to be auto incremented to add new data by other applications?
Thank you in Advance.
Alaeddine Saadaoui.
