Midpoint in .NET 3.5 & ArcGIS Engine 10.0
769
10-29-2013 01:01 PM
eddixoncastillo
Hello evreyone:
I'm programming a tool similar to ArcMap's Midpoint (Feature Constructor in Arcmap).
I draw de line with a  INewLineFeedback object and works well, but de mid point is well calculated, but doesn't refresh properly.
i'm wondering if someone knows how i can resolve this....
I attacht my code and a screenshot with the trouble.
Thanks for your attention
[ATTACH=CONFIG]28702[/ATTACH]
using System;
using System.Drawing;
using System.Runtime.InteropServices;
using ESRI.ArcGIS.ADF.BaseClasses;
using ESRI.ArcGIS.ADF.CATIDs;
using ESRI.ArcGIS.Controls;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Display;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.Geodatabase;
using System.Windows.Forms;
namespace Editor_Tools
    /// <summary>
    /// Summary description for Midpoint.
    /// </summary>
    [Guid("5a956a79-8872-4f48-aec9-5b048a307c31")]
    [ClassInterface(ClassInterfaceType.None)]
    [ProgId("EngineClassLibrary1.Midpoint")]
    public sealed class Midpoint : BaseTool
        #region COM Registration Function(s)
        [ComRegisterFunction()]
        [ComVisible(false)]
        static void RegisterFunction(Type registerType)
            // Required for ArcGIS Component Category Registrar support
            ArcGISCategoryRegistration(registerType);
            // TODO: Add any COM registration code here
        [ComUnregisterFunction()]
        [ComVisible(false)]
        static void UnregisterFunction(Type registerType)
            ArcGISCategoryUnregistration(registerType);
            // TODO: Add any COM unregistration code here
        #region ArcGIS Component Category Registrar generated code
        /// <summary>
        /// Required method for ArcGIS Component Category registration -
        /// Do not modify the contents of this method with the code editor.
        /// </summary>
        private static void ArcGISCategoryRegistration(Type registerType)
            string regKey = string.Format("HKEY_CLASSES_ROOT\\CLSID\\{{{0}}}", registerType.GUID);
            ControlsCommands.Register(regKey);
        /// <summary>
        /// Required method for ArcGIS Component Category unregistration -
        /// </summary>
        private static void ArcGISCategoryUnregistration(Type registerType)
            ControlsCommands.Unregister(regKey);
        #endregion
        #endregion
        #region private members
        private IHookHelper m_hookHelper;
        private IEngineEditor engineEditor ;
        private IEngineEditSketch engineEditSketch;
        private IPoint midPoint;
        private IPoint f;
        private IPoint s;
        private INewLineFeedback pFeedbackEnv;
        #endregion
        public Midpoint()
            // TODO: Define values for the public properties
            base.m_category = ""; //localizable text
            base.m_caption = "";  //localizable text
            base.m_message = "";  //localizable text
            base.m_toolTip = "Mid point";  //localizable text
            base.m_name = "";   //unique id, non-localizable (e.g. "MyCategory_MyTool")
            try
                // TODO: change resource name if necessary
                string bitmapResourceName = GetType().Name + ".bmp";
                base.m_bitmap = new Bitmap(GetType(), bitmapResourceName);
                base.m_cursor = new System.Windows.Forms.Cursor(GetType(), GetType().Name + ".cur");
                engineEditor = new EngineEditorClass();
                engineEditSketch = engineEditor as IEngineEditSketch;
                midPoint = new PointClass();
            catch (Exception ex)
                System.Diagnostics.Trace.WriteLine(ex.Message, "Invalid Bitmap");
        #region Overridden Class Methods
        /// <summary>
        /// Occurs when this tool is created
        /// </summary>
        /// <param name="hook">Instance of the application</param>
        public override void OnCreate(object hook)
            if (m_hookHelper == null)
                m_hookHelper = new HookHelperClass();
            m_hookHelper.Hook = hook;
            // TODO:  Add Midpoint.OnCreate implementation
        /// <summary>
        /// Occurs when this tool is clicked
        /// </summary>
        public override void OnClick()
            // TODO: Add Midpoint.OnClick implementation
        public override void OnMouseDown(int Button, int Shift, int X, int Y)
            // TODO:  Add Midpoint.OnMouseDown implementation
            IActiveView pActiveView;
            IScreenDisplay pScreenDisplay;
            pActiveView = m_hookHelper.ActiveView;//My.ArcMap.Document.FocusMap;
            pScreenDisplay = pActiveView.ScreenDisplay;
            IPoint pPoint = new PointClass();
            pPoint.PutCoords(X, Y);
            pPoint = Transforms.GetMapCoordinatesFromScreenCoordinates(pPoint, pActiveView);
            if (pFeedbackEnv == null)
                pFeedbackEnv = new NewLineFeedbackClass();
                pFeedbackEnv.Display = pActiveView.ScreenDisplay;
                pFeedbackEnv.Start(pPoint);
                f = pPoint;
            else
                //pFeedbackEnv.AddPoint(pPoint);
                s = pPoint;
                double dx = (f.X + s.X) / 2;
                double dy = (f.Y + s.Y) / 2;
                midPoint.PutCoords(dx, dy);
                engineEditSketch.AddPoint(midPoint, true);
                pFeedbackEnv = null;
                pActiveView.PartialRefresh(esriViewDrawPhase.esriViewAll, null, pActiveView.Extent);
            //engineEditSketch.AddPoint(pPoint, true);
        public override void OnMouseMove(int Button, int Shift, int X, int Y)
            // TODO:  Add Midpoint.OnMouseMove implementation
            if (pFeedbackEnv != null)
                pFeedbackEnv.MoveTo(pPoint);
                s = pPoint;
                double dx = (f.X + s.X)/2;
                midPoint.PutCoords(dx,dy);
                DrawPoint(pActiveView, midPoint);
        public override void OnMouseUp(int Button, int Shift, int X, int Y)
            // TODO:  Add Midpoint.OnMouseUp implementation
        public override void OnDblClick()
            base.OnDblClick();
            engineEditSketch.FinishSketch();
        public override bool Enabled
            get
                if ((engineEditor.EditState == esriEngineEditState.esriEngineStateEditing))
                    return base.Enabled == true;
                return base.Enabled == false;
        #endregion
        public void DrawPoint(ESRI.ArcGIS.Carto.IActiveView activeView, IPoint point)
            if (activeView == null)
                return;
            ESRI.ArcGIS.Display.IScreenDisplay screenDisplay = activeView.ScreenDisplay;
            // Constant
            screenDisplay.StartDrawing(screenDisplay.hDC, (System.Int16)ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache); // Explicit Cast
            ESRI.ArcGIS.Display.ISimpleMarkerSymbol simpleMarkerSymbol = new ESRI.ArcGIS.Display.SimpleMarkerSymbolClass();
            ESRI.ArcGIS.Display.ISymbol symbol = simpleMarkerSymbol as ESRI.ArcGIS.Display.ISymbol; // Dynamic Cast
            screenDisplay.SetSymbol(symbol);
            ESRI.ArcGIS.Display.IDisplayTransformation displayTransformation = screenDisplay.DisplayTransformation;
            // x and y are in device coordinates
            //ESRI.ArcGIS.Geometry.IPoint point = displayTransformation.ToMapPoint(x, y);
            screenDisplay.DrawPoint(point);
            screenDisplay.FinishDrawing();
            //activeView.PartialRefresh(esriViewDrawPhase.esriViewNone , null, activeView.Extent);
