Metadata Storage in Personal Geodatabase
1669
01-03-2014 12:09 PM
WilliamTrachtman
Where is the metadata "file" stored in a personal geodatabase (ie. the xml file associated with shapefiles)?
Clay
NidhinKarthikeyan
Honored Contributor
You can find it in 'GDB_Items' table.
WilliamTrachtman
I found some of it there in the "Documentation" column, but not everything.  This is what I found:
<metadata xml:lang="en"><eainfo><detailed><enttyp><enttypl>Export_Output</enttypl></enttyp><attr><attrlabl>OBJECTID</attrlabl><attrdef>Internal feature number.</attrdef><attrdefs>Esri</attrdefs><attrdomv><udom>Sequential unique whole numbers that are automatically
In arccatalog, I changed the title in the metadata, it must be stored somewhere?
WilliamTrachtman
Nevermind, I see it is the documentation field.  How can I get MS Access to show the entire field?
