Message notification direction in relationship classes: pratically useless?
7080
02-05-2015 08:35 AM
RobertoRossi
ArcGIS for Desktop Help tells us that, using Relationship classes in Geodatabase, we can use a Message notification direction in order to manage "...actions that require an update of one feature to trigger an update in its related features": for example "When you update a feature, you want an attribute in a related feature to update automatically".
To manage this kind of behaviors we can set a Message notification direction to 4 different directions (None, Forward, Backward, Both).
In fact everytime we create a relationship class we have to chose one of the 4 direction... but...
The strange thing is that, unlike the other ArcGIS desktop tools, which normally are "Ready to use", in this case, this operation needs a "custom programming", and the choise of the message notification direction is pratically useless!
Is there any "Almost-Ready to use" add-on which can help non-programming user to achieve the objective?
Roberto Rossi
Padua University
PatrickDenny
Found this when wondering about message direction myself. There is a table outlining all the built-in message direction functionalities in the Message Notification Direction section of ESRI's Relationship Class Properties documentation page.
Here's the table:
DirectionEffect on simple relationshipsEffect on composite relationships
Forward
No effect unless customized with programming
  • Deleting origin deletes destination
  • Moving or rotating origin moves or rotates destination
  • No other effect unless custom behavior is programmed
Backward
Both
None
Prevents messages from being sent, slightly improving performance
  • Prevents other messages from being sent, improving performance slightly
DavidRichey
I am wondering if there are examples of the custom programming necessary. I have not been able to find them myself, and would like to experiment. I found my way to the table Patrick displays above, but nothing further. I am also wondering if this functionality transfers to ArcGIS Online for automation of related features.
TLandrum
Has anyone discovered how or where one can "program custom behavior"? I'm at a loss just like the others on this message.
