Memory reference error
1976
03-25-2012 06:30 PM
GurminderSingh_Saini
Hello
My workstations is Z400 'Zeon, fantastic outcome and performance since the day one. I moved to Arc10 a year ago, all going well. But mostly working on 'Editing' my workstation goes 'damn slow'. Every single trace or creating new feature takes about 3-5 mins to bring to tool to position. And while editing and saving the feature prompts me error "The instruction at "0x1005z2db" referenced memory at "0x00000000". The memory could not be "read". Click OK to terminate the program and/or CANCEL to debug the program. Doe not matter which option you choose it terminates the application and you get your editing version lost, no other option than re do again. Some time the error "ERROR 000426 : Out of Memory, There is not enough memory.
Mostly I reboot the system and keep only one application 'Map document' running, still facing the same error... I'm so over it.
I switched on to ArcInfo/ArcEditor/ArcView but the error persists.
Any solution please.
KevinBurke
Good morning,
I have ran into that error a few times, but its resolution was different in each case. Here are a few suggestions:
- As a test, import your data into a new file geodatabase on the local machine and then try and edit.
- Try editing that new feature class in a new blank mxd.
- Check your machines ability to run ArcGIS 10 against the system requirements: http://resources.arcgis.com/content/arcgisdesktop/10.0/arcgis-desktop-system-requirements (click the hyperlink called 'Check your computer's ability to run ArcGIS')
- Install Service Pack 4: http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=66&MetaID=1843
These tests may give some insight into whether the issue is unique to a particular mxd, data, or if the data is stored across a network location.
Thank you.
