Memory limits of file geodatabase?
1305
5
11-23-2010 10:59 AM
MattRosales
Hi All,
I've been importing shapefiles into one geodatabase by way of a python script. The database is now 13gb, and even after compacting it, I cannot view or in any way work with the geodatabase, as I get "out of memory" errors. My computer has 8gb of RAM - are geodatabase sizes limited to the amount of installed memory? I am surprised that they do not operate using virtual memory (swap).
Examples of some of the error messages:
Not enough storage is available to complete this operation.; (code 8007000E)
Out of memory
Failed to execute CompressFileGeodatabaseData
Thanks for the insights,
HelenYang
Instead of trying to compress the whole gdb, you may try to compress individual feature dataset or feature class.
MattRosales
Thanks for the input - unfortunately I can't list the contents of the geodatabase without incurring an out of memory error. The strangest facet of this is arcpy.ListFeatureClasses() returns null, but if I already know the name of a feature class, it can be manipulated, but without being able to list them, I don't know the individual names of the feature classes to compress... arcpy.ListFiles() crashed the last two times I attempted it also. Ugh!
VinceAngelo
Esri Esteemed Contributor
It sounds like your FGDB was corrupted, and the compress made things worse.
- V
MattRosales
Is there any way to repair a FGDB? Or in any case get some sort of diagnostics out of it to know for sure?
VinceAngelo
Contact Tech Support; they're the only folks who might have tools like that.
- V
