Map of Superfund Sites
4874
5
12-06-2014 10:02 AM
SpiroKorizis
I am trying to create a map of all Superfund sites in the U.S., and of course it isn't as easy as I thought it would be. I think I have downloaded all the necessary information, but can't figure put how to create this map. I have a basemap, I downloaded the shapefiles from the EPA, but now I am stuck. When I unzip the shapefiles, I have a bunch of excel tables, some of which do contain latitude, longitude information. I just need to do some preliminary mapping for a future project and I have a grand total of three months of GIS experience, so try and give a detailed explanation as to what I should do. Thanks.
ElliottRobinson
Here's what I did:
1. Download geodatabase from www.epa.gov/enviro/geo_data.html
     - the files will typically end up in your Temp folder
     - extract the files into a folder in Windows Explorer, call it epa
2. Open a new blank map in ArcMap.
3. Click on the Catalog window icon to open it
4. Click on the Connect to Folder icon
     - browse to your epa folder and select it
5. The epa folder is now in the Catalog window
      - click on the + sign to expand the epa folder in the Catalog window
6. Right click on the FRS_INTERESTS.gdb icon
     - select Make Default Geodatabase
     - the default geodatabase is where all your geographic data is stored for this project
7. Click on the Add Data icon
     - select the Facilities layer
8. Right click Facilities
     - select Open Attribute Table to select the facilities you are interested in, or to manipulate the data
ElliottRobinson
Here's what I did:
SpiroKorizis
Thanks for this. I followed your steps and was able to do what I wanted.
DanPatterson_Retired
stackexchange has some responses to your question
VinceAngelo
Esri Esteemed Contributor
If you really want a response from GeoNet, you should post questions "In a place", instead of in your own private discussion space.  You can correct this by clicking on the question title and using the "Move" action on the right-side "Action" menu list.
You should also always include keyword tags, so that those who have set up custom streams might find your post.
- V
SpiroKorizis
Thanks. I will keep that in mind for any future inquiries.
