Managing the OBJECTID Field
1091
07-18-2011 03:50 PM
DavidTriggs
I have a series of tables I have created in ArcCatalog which I want to populate externally from some code I have written in .NET.
I had assumed that the OJBECTID field was a sequence field, but this is obviously not the case. How is the OBJECTID number derived for each row in each layer if it is not a sequence field? Do you run a MAX(OBJECTID) first prior to each Insert?
David
