.lyr or raster image to point shapefile
2006
04-29-2011 07:15 AM
SeanGerhardt
Would anyone happen to know how to convert a .lyr or raster image to a point shapefile? I've heard that .lyr conversions to points isn't possible in older software, but I was wondering if this changed at all.
What I eventually want to do is a pixel by pixel analysis, so I would need to convert every pixel of a layer or raster image(landsat 7 image) to a point. Any ideas?
Thanks in advance!
TimothyHales
Esri Notable Contributor
Try using the Raster to Point tool.
michaelcollins1
Use the Raster to Point tool under Conversion Tools
michaelcollins1
Do you have to convert it to a shape file? There are many ways to do a pixel by pixel analysis on a raster file.
SeanGerhardt
Hey guys,
The Raster to Point tool worked perfectly, but only if the .lyr has associated "data". For example, a Landsat image .tiff will convert to a point shapefile, but a esri world imagery .lyr will not. Interesting.
I had to convert to a shapefile since I will eventually take the interstection of those points from the pixels of the .lyr with another shapefile.
The Landsat image was very low resolution, yielding a point every 30 meters or so, which is not as accurate as I would like. Does anyone know if MODIS imagery files are readibly available somewhere on the web?
Thanks again for all the help! : )
