Loading Multiple Shapefiles into a SDE Feature Class
687
11-08-2010 05:10 AM
StevenRussell_Jr_
I have 2,600 LiDAR contour shapefiles that i would like to "merge" into one Feature Class in SDE.  All have the same schema.
I found the "SIMPLE DATA LOADER" tool in SDE.  However, that does not allow me to select multiple shapefiles, and i have to load each file individually.
Is there a way to batch or load multiple shapefiles at once into a SDE Feature Class?
Any help you can provide will save an intern from loading 2,600 files one at a time 😉
Thank you.
Steve
StevenRussell_Jr_
As always, after i post the question i find the answer.
If you use the Append command it allows you to add multiple shapefiles to a Feature Class in SDE.
