licensed for Geodatabase in Oracle RAC
3649
11-12-2015 12:05 PM
Arturo_FranciscoAcosta_Bazán
any of you know what the licensing that applies to an geodatabase  implementation in  Oracle RAC, when more than 01 Server ( 2-3-..)  but one database. ?
Tags (1)
VinceAngelo
Esri Esteemed Contributor
Esri does not license Oracle deployments.  It licenses ArcGIS for Server hosts.  Enterprise geodatabases require an ArcGIS for Server license.
Back in the days when ArcSDE existed, the licensing was applied where the application server resided, but ArcSDE doesn't exist, and neither do application servers.  You can run a fifty node Oracle RAC database, and it could still only require one ArcGIS for Server seat (probably ineffectively, but that's a technical issue), depending on how your ArcGIS Server site(s) is(are) configured.  Since you did not address how your  ArcGIS for Server sites and servers are deployed, there's no way to say how many seats of ArcGIS Server are required in your configuration.
The fact is, licensing is NOT a technical issue -- it's a contractual one, which is why I recommended you speak with the folks who know the most about contracting (who are not over-abundant here in the technical forums).  Yes, the issue impacts technical deployment, but that just reinforces getting a proper understanding from the folks who are working with licensing on a regular basis (and presumably know what you have licensed to date).
The usual steps for ArcGIS for Server deployment are:
  1. Collect requirements
  2. Design an initial implementation
  3. Cost the implementation plan
  4. Redesign in light of costing (loop back to 3 until plan is most cost-effective)
  5. Execute the purchase
  6. Install and configure the implementation as per design
  7. Maintain the GIS deployment
This GeoNet forum is more about the nuts-and-bolts of steps 6 & 7, and only lightly addresses steps 1 & 2.  The best way to understand steps 2-4 is to start by discussing the licensing model with your local Esri rep.  They'll be able to give you an overview of how ArcGIS licensing works and some boilerplate Server designs from which to get started.  If they can't answer technical questions, they'll have access to experts who can.  Ed Services has a three-day class on System Architecture Design Strategies, and the Systems Integration team has a wiki site, but neither is going to address licensing differences between single-node and RAC deployment of enterprise geodatabases (because there aren't any).
- V
VinceAngelo
ArcGIS for Server is licensed by ArcGIS for Server deployments.  If you have a redundant set of ArcGIS Server sites accessing the RAC set, those hosts would be licensed, depending on whether the sites were configured active-passive or active-active.
In general, licensing questions should be directed to your Esri account manager or Customer Service representative -- asking fellow users (or even Esri staff) who are not parties to your license agreement with Esri isn't going to generate a legally binding answer.
- V
I understand your answer is referring to the server of publication on ArcGIS Server (active - passive) - deployments scenaries .Not this referred to the Information Store (geodatabase - Data Store).
What I mean is that in an architecture Oracle may be more than one processing server : S1, S2 (nodes in RAC) but a single instance database ( p.e. ORCL more common ) that stores a GDB only supported for some of these servers and failover It used the other (perhaps others - more 1.2.3). That is my question . if licensing in server for data Store is similar to the case of Server for publication(windows - Linux ) , for server or node in some cluster.
It right , it is a commercial issue, but that knowledge does not make us in the realization of this consultation.I will have no contact or interview with the client to sell.
If knowledge of licensing was completely alien to us the technical, then in presentations  ESRI UC would be not mentioned.
If you check the presentation of the ESRI UC15 (Amit K & Jim - Admin Oracle .. ) they they comment and notes about licensing, in the latter case on the PDB in Oracle 12C. license for more 2 PDB ,etc
VinceAngelo
- V
