libsdeora11gsrvr93.so error with SDE 9.3.1
2763
09-29-2010 01:23 PM
by Anonymous User
Not applicable
Original User: peasland
I am running Oracle 11g on Linux 64-bit. I installed SDE 9.3.1 with no problems. SDE starts just fine. When I attempt to connect to SDE with ArcCatalog, I get the following error in my sde.log file:
/u01/app/sde/sdeexe93/bin/gsrvr: error while loading shared libraries: libsdeora11gsrvr93.so: cannot open shared object file: No such file or directory
I have verified that the lib file is readable. It is owned by sde after all. The sde user has oinstall as its primary group. LD_LIBRARY_PATH is set correctly in my environment and in my dbinit.sde file.
Any other suggestions?
Cheers,
Brian
by Anonymous User
Not applicable
Original User: vangelo
What are the contents of the PATH, LD_LIBRARY_PATH, SDEHOME, and ORACLE_HOME
environment variables?
What does "file $SDEHOME/bin/sdelayer $ORACLE_HOME/bin/sqlplus" return?
What does "ldd  `which gsrvr`" return?
What shell are you using?
- V
by Anonymous User
Not applicable
- V
LD_LIBRARY_PATH = /u01/app/sde/sdeexe93/lib:/usr/lib:/lib:/u01/app/oracle/product/db/11.1.0/lib
SDEHOME = /u01/app/sde/sdeexe93
ORACLE_HOME = /u01/app/oracle/product/db/11.1.0
PATH = /u01/app/sde/sdeexe93/bin:/u01/app/oracle/product/db/11.1.0/bin:.:/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/usr/NX/bin:/home/sde/bin
[prompt]$ file $SDEHOME/bin/sdelay/u01/app/sde/sdeexe93/bin/sdelayer: ELF 64-bit LSB executable, AMD x86-64, version 1 (SYSV), for GNU/Linux 2.4.0, dynamically linked (uses shared libs), for GNU/Linux 2.4.0, stripped
[prompt]$ file $ORACLE_HOME/bin/sqlplus
/u01/app/oracle/product/db/11.1.0/bin/sqlplus: ELF 64-bit LSB executable, AMD x86-64, version 1 (SYSV), for GNU/Linux 2.6.9, dynamically linked (uses shared libs), for GNU/Linux 2.6.9, not stripped
[prompt]$ ldd `which gsrvr`
        libsdeora11gsrvr93.so => /u01/app/sde/sdeexe93/lib/libsdeora11gsrvr93.so (0x00002b513e109000)
        libsde.so => /u01/app/sde/sdeexe93/lib/libsde.so (0x00002b513f27a000)
        libsg.so => /u01/app/sde/sdeexe93/lib/libsg.so (0x00002b513f72f000)
        libpe.so => /u01/app/sde/sdeexe93/lib/libpe.so (0x00002b513f880000)
        libicuuc.so.22 => /u01/app/sde/sdeexe93/lib/libicuuc.so.22 (0x00002b513fb5e000)
        libxerces-c.so.27 => /u01/app/sde/sdeexe93/lib/libxerces-c.so.27 (0x00002b513fd18000)
        libclntsh.so.11.1 => /u01/app/oracle/product/db/11.1.0/lib/libclntsh.so.11.1 (0x00002b5140225000)
        libXm.so.3 => /usr/lib64/libXm.so.3 (0x00002b514291a000)
        libXmu.so.6 => /usr/lib64/libXmu.so.6 (0x0000003014e00000)
        libXp.so.6 => /usr/lib64/libXp.so.6 (0x00002b5142dbb000)
        libXt.so.6 => /usr/lib64/libXt.so.6 (0x0000003028000000)
        libSM.so.6 => /usr/lib64/libSM.so.6 (0x000000301f000000)
        libICE.so.6 => /usr/lib64/libICE.so.6 (0x000000301dc00000)
        libXext.so.6 => /usr/lib64/libXext.so.6 (0x0000003017600000)
        libX11.so.6 => /usr/lib64/libX11.so.6 (0x0000003016a00000)
        libg2c.so.0 => /usr/lib64/libg2c.so.0 (0x00002b5142fc5000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00002b51431e6000)
        libdl.so.2 => /lib64/libdl.so.2 (0x0000003014a00000)
        libstdc++.so.5 => /usr/lib64/libstdc++.so.5 (0x00002b5143401000)
        libm.so.6 => /lib64/libm.so.6 (0x0000003014600000)
        libc.so.6 => /lib64/libc.so.6 (0x0000003014200000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003021c00000)
        libicudata.so.22 => /u01/app/sde/sdeexe93/lib/libicudata.so.22 (0x00002b51436dd000)
        libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003023800000)
        libnnz11.so => /u01/app/oracle/product/db/11.1.0/lib/libnnz11.so (0x00002b5143d32000)
        libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003018200000)
        libaio.so.1 => /usr/lib64/libaio.so.1 (0x00002b5144184000)
        libXau.so.6 => /usr/lib64/libXau.so.6 (0x0000003016200000)
        libXdmcp.so.6 => /usr/lib64/libXdmcp.so.6 (0x0000003016e00000)
        /lib64/ld-linux-x86-64.so.2 (0x0000003013e00000)
I am using the BASH shell.
You didn't ask for it, but here is the contents of my dbinit.sde file:
# dbinit.sde
set SDEHOME=/u01/app/sde/sdeexe93
set ORACLE_HOME=/u01/app/oracle/product/db/11.1.0
set LD_LIBRARY_PATH=$SDEHOME/lib:/usr/lib:/lib:$ORACLE_HOME/lib
set ORACLE_SID=fgodev3
I think that is everything you asked for.
Thanks!
Brian
VinceAngelo
Esri Esteemed Contributor
Does the giomgr process user's .profile, .bash_profile or .bashrc clear the contents of
PATH or LD_LIBRARY_PATH?
By the time the dbinit.sde is consulted, it's too late to set the SDEHOME or LD_LIBRARY_PATH.
My ArcSDE boot script executes $SDEHOME/etc/.profile to establish database-specific
environment variables before executing 'sdemon -o start'. This way I only need to put the
ORACLE_SID or TWO_TASK (and possibly NLS_LANG) in the dbinit.sde (and can use the
same profile for all Oracle instances, regardless of ArcSDE release).
My complete multi-instance Linux boot script framework is buried in the se_toolkit release
tree (in all release bundles, under samples/boot/redhat_etc).
- V
### $SDEHOME/etc/.profile ###
ORACLE_HOME=/opt/oracle/product/10.2.0/db32
LD_LIBRARY_PATH=$ORACLE_HOME/lib:$LD_LIBRARY_PATH
NLS_LANG=AMERICAN_AMERICA.AL32UTF8
export ORACLE_HOME NLS_LANG LD_LIBRARY_PATH
### $SDEHOME/etc/dbinit.sde ###
set ORACLE_SID=xxxx10g2
unset TWO_TASK
### /etc/init.d/arcsde ###
Start_SDE()
# .. Set environment variables
SDEHOME=$2
PATH=$SDEHOME/bin:$origPATH
LD_LIBRARY_PATH=$SDEHOME/lib:$origLD
SDEVERBOSE=$3
export SDEHOME PATH LD_LIBRARY_PATH SDEVERBOSE
# .. Retrieve password
if [ -f $SDEHOME/etc/.passwd ]; then
sdepass=`cat $SDEHOME/etc/.passwd`
else
report_error ERROR &&
printf "\t--> $SDEHOME/etc/.passwd not found\n"
return 1
fi
# .. Execute etc/.profile (if present)
if [ -f $SDEHOME/etc/.profile -a ! -x $SDEHOME/etc/.profile ]; then
printf "\t--> $SDEHOME/etc/.profile not executable\n"
return 1
fi
test -x $SDEHOME/etc/.profile && . $SDEHOME/etc/.profile
# .. Execute command
sdemon -o start -i $1 -p $sdepass >> $logFile 2>&1
by Anonymous User
Not applicable
Those files do not clear the env vars. I do not have a .profile file. Here is the contents of my .bashrc file:
# .bashrc
# Source global definitions
if [ -f /etc/bashrc ]; then
        . /etc/bashrc
fi
Here is my .bash_profile file:
# .bash_profile
# Get the aliases and functions
if [ -f ~/.bashrc ]; then
        . ~/.bashrc
fi
# User specific environment and startup programs
PATH=.:$PATH:$HOME/bin
export PATH
export SDEHOME=/u01/app/sde/sdeexe93
export ORACLE_HOME=/u01/app/oracle/product/db/11.1.0
export ORACLE_SID=fgodev3
export LD_LIBRARY_PATH=$ORACLE_HOME/lib:$SDEHOME/lib
export PATH=$SDEHOME/bin:$ORACLE_HOME/bin:$PATH
To start SDE, I just entered:
sdemon -o start -p password
So I'm not doing anything fancy here. Just set the env vars and startup SDE.
Brian
VinceAngelo
What user starts the 'sdemon' application?
One way to find out what's wrong with the environment is to replace 'gsrvr'
with a shell script that dumps the environment (and possibly a ldd of the
superceeded gsrvr).
It's just about time to contact Tech Support on this issue.  The only time
I've seen something similar was on a client's HP/UX host where the 64-bit
install binaries had been corrupted by a silent disk failure.
- V
