Labeling Survey Points
3044
11-14-2017 09:17 AM
BrendanAnnetts
I've been asked to inventory culverts in my work region which means a lot of survey points.  I've been trying to label all these points into a user friendly map to show to my municipality representatives.  Here's what I've gotten so far (see attached) , but my labels are still to "ugly"  some of them have been placed so that the leaders overlap other leaders and other various issues.  Can I manually tweak the position of labels?  Any tips or advice would be much appreciated.
AdrianWelsh
MVP Honored Contributor
Jonathan,
It's hard to see your screenshot. Can you make it bigger?
Either way, have you enabled the Maplex Label Engine?
Exercise 1: Enabling the Maplex Label Engine and adding the Labeling toolbar—Help | ArcGIS for Deskt...
Maplex has many options of manipulating labels to help make them look nicer.
BrendanAnnetts
here's a more zoomed in screen shot, The quality isn't great but basically the issue I'm left with now (using Maplex) is my leaders crossing over each other. Is there a way to select that specific label and move it manually? MidnightYell2003
AdrianWelsh
Yes, you can convert your labels to annotation, then you have the freedom to do whatever you want with them:
Converting labels to annotation—Help | ArcGIS for Desktop
BrendanAnnetts
Thanks, I'll give this a try and see how it goes.
AdrianWelsh
Johnathan, were you able to find success with this?
