Joining tables by multiple attributes
2786
01-20-2016 09:43 AM
paulmcburney
Hey everyone,
I am trying to join a table I created to a boundary file. I am trying to show values by county but being that the same county name appears in multiple states I'm having difficulty joining the tables correctly. I can only do a "join by attributes". I need to join both county and state but I can only select one attribute for the join which results in a table with the same county name that is located in other states.
Thanks
XanderBakker
Esri Esteemed Contributor
Is it an option to create an additional field that concatenates the state and the county?
paulmcburney
Yes just figured that out. Problem solved!
Thanks!
