Issues with reconcile GP tool
2610
03-24-2013 04:22 PM
RobertKeane1
I am having trouble with the reconcile version GP tool. When I try to run the tool there are no versions turning up in the "Edit version" list box. If I try to run the tool (even with an old process out of the results log) I get an error message as follows;
ERROR 999999: Error executing function.
The SE_VERSIONINFO object was not initialized
Insufficient permissions
I can, however, run the reconcile within an edit session in ArcMap and it works fine.
It is a database issue as the process works fine on other databases
I am run version 10 on Oracle.
Any ideas
JensHaffner
I may have hit the same problem from Python, where I call arcpy.ReconcileVersions_management.
The Error message is the same, and I can reconcile and post the version from ArcMap.
I'm running ArcGIS Desktop 10.1 with an Oracle ArcSDE database.
It's probably the SE_INVALID_VERSIONINFO_OBJECT (-180) error message, but the description:
[INDENT]�?�The VERSIONINFO object has not been initialized�?�[/INDENT]
is not much of a help.
RussellBrennan
Can you post the python code you are running?
TinaMorgan1
Hello, I am seeing this issue as well.  I was wondering if there was a resolution that any of you found?  Please post if there is.
