Is there any specific user requirement for Publishing?
4812
11
11-29-2024 01:48 AM
Yogesh_Chavan
We have ArcGIS Pro 3.3, Enterprise 11.3 and SQL Server 2022.
In our SQL Databases(SDE), the data is only owned by a singe user X.
We would like to know what is the best or recommended way of publishing services from ArcGIS Pro to Enterprise?
Question: In our case as we have only one user being the data owner, should we have a new dedicated user for publishing? or is it okay to keep using the user X for publishing?
Any help on this would be appreciated!!
VinceAngelo
Esri Esteemed Contributor
If you only have one login you are not anywhere close to best practice. Publishing with the table owner means that any zero-day security bug would allow "read-only" users to delete the contents of your database (or just systematically corrupt it), with no way to determine who did it.
It is NOT okay to keep using user X for publishing. You need to create a browsing login and user, and grant it only SELECT access to the tables involved in publishing (and nothing else), then publish connected as that user.
Using enterprise-class database tools means having an enterprise-class security model. There are entire books on database security, but you can start with a chapter in any database administration guide.
- V
DanPatterson
MVP Esteemed Contributor
Member roles—ArcGIS Online Help | Documentation
Publisher—User privileges plus the ability to publish features and map tiles as hosted web layers. Members assigned the Publisher role can also perform analysis on layers in maps. The Publisher role is compatible with the Creator, Professional, and Professional Plus user types.
... sort of retired...
Yogesh_Chavan
Thank you for having a look.
Question: In our case as we have only one user being the data owner, should we have a new dedicated user for publishing? or is it okay to keep using the same for publishing?
VinceAngelo
- V
Yogesh_Chavan
Thank you so much @VinceAngelo for sharing your ideas.
In our environment this user X is only used for almost all new files creations(Dataset, Feature-classes and tables), and we have other users use the databases using windows auth, other users do not use this login, they only work with editing this data in ArcGIS Pro, or ArcGIS Portal Map Viewer.
So, its like the user X acts as admin for managing and publishing only. Whereas other users continue working on data.
VinceAngelo
Never, never, NEVER, NEVER publish as the data owner.  This is a HUGE security risk.  Just don't do it.
This is a Security Modeling 101 issue. The principle here is "minimum necessary privilege". The owner has way too much access to the table. Instead, create one or more browse users, and roles for each kind of access, and grant access to the tables to the roles, and grant roles to users. Publish data with the user holding the least possible access to make effective use the data. If some apps need UPDATE, but others don't, publish with different publishing users (e.g., "app1_pub" & "app2_pub"), only granting the minimum necessary to each.
- V
Yogesh_Chavan
Thank you @VinceAngelo for sharing this information.
JTLancer
There seems to be an exception to this when working with branch versioned data and utility networks.  From what I am seeing, it is required to use the data owner to publish a feature service referencing data in an enterprise geodatabase.
Not sure what security implications this has as we have also followed your suggestion in other circumstances by having a two publisher users:  one with view only(db_datareader) and one with edit (db_datareader, and db_datawriter).  We could get more granular with this but it seems to work well for our organization needs
https://community.esri.com/t5/mapping-and-charting-enterprise-databases/mapping-and-charting-solutio...
VinceAngelo
Yes, this is unfortunately true.
- V
MarceloMarques
@Yogesh_Chavan - please read my community.esri.com blog article below
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
