Is there a way to roll back a database to specific time?
1314
01-31-2025 04:12 AM
GeorgeJones9272
Hi all, I'm working with an enterprise database (.sde) and was wondering if there's a way to roll it back to a specific place in time to view features that were there under each of the datasets?
thanks George
Tags (3)
George_Thompson
Esri Notable Contributor
If you had archiving on the feature class that may be possible: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/what-is-archiving-.htm
For the entire enterprise geodatabase, that is more difficult. If you roll back (restore) to point in the past, it will roll back everything.
If you have a backup from that time period, you may be able to restore to another instance of your RDBMS and look there. A lot would depend on your backups and the RDBMS that you are using.
--- George T.
GeorgeJones9272
Ok will give it a shot. thanks!
George_Thompson
Just to be clear, if you enable archiving now it will NOT have the edits from the past.
--- George T.
