Is there a proper way to order a field column for lat and long ?
4905
11
08-30-2017 12:09 PM
DEAF_PROBERT_68
Honored Contributor
Is there a proper way to order column for latitude and longitude ? I have seen some people put their columns vice versa So, I am wondering if there is a proper way for this. So, would add for new column for latitude first and then longitude second ..but I am not sure...
Here is the example :
Another example here:
Asrujit_SenGupta
I don't think think there is any specific order as such...generally we mention Lat ahead of Long...
however check this thread for a more formal response:
google maps - Preferred order of writing latitude & longitude tuples - Stack Overflow
JayantaPoddar
As long as you are keeping the values in the columns correctly, the order shouldn't matter.
We usually write the coordinates as XY. So X (Longitude) could be placed before Y (Latitude) in an attribute table.
But there is no mandate that says Longitude should be placed before Latitude values.
Think Location
DEAF_PROBERT_68
Honored Contributor
In order from XY   to LONG LAT  to UTM  should be like this  UTM Easting and UTM Northing ? Am I correct ?
Asrujit_SenGupta
Yes!
The terms easting and northing are geographic Cartesian coordinates for a point. Easting refers to the eastward-measured distance (or the x-coordinate), while northing refers to the northward-measured distance (or the y-coordinate).
Source: Easting and northing - Wikipedia
DEAF_PROBERT_68
Honored Contributor
Thanks. Had to make sure it is correct... Phew... and thanks for the link too.
DEAF_PROBERT_68
Honored Contributor
It can go pretty confusing so that is why I got to be careful.
IanFrakes1
I've found that if I use field names XCOORD (Longitude) & YCOORD (Latitude) they are often automatically recognised by the software and pop up conveniently in selection boxes. It used to work that way in MapInfo.
DEAF_PROBERT_68
Honored Contributor
Yes I saw that after I post this question and in a few hours later I looked it around and I saw that tool that does that .. It would be nice if they just label Longitude and Latitude instead of XCOORD and YCOORD...
Thanks for the info.
IanFrakes1
I consider 'Latitude and Longitude' as jargon, it confuses non-GIS colleagues and clients, virtually everyone knows which way up 'X and Y' are.
Because I don't use that terminology I forget which is which myself (I'm a Forester that does GIS, not the other way around) it wasn't until I read Dava Sobel's excellent book Longitude, that I can consistently remember Longitude is 'X'
