Is it possible to change a the path of a dynamic hyperlinks?
3804
10
07-17-2016 10:39 PM
DanielRodriguez
Is it possible to change the path of dynamic hyperlinks?
I hyperlink a shapefile with 100 polygons with each polygon contain 2 or more hyperlink per polygon to pdfs using the dynamic hyperlink through the identity tool.
I moved the folder containing the pdfs that were used to hyperlink  to our network so the mxd containing the shapefile file would view by other people.
My question is it possible to update path to the network containing the pdf folder in your mxd file?
I guess the Hyperlink base under the Map Document Properties will not change the path to the pdf folder?
Daniel
DanielRodriguez
Hello Dan
So the solution is to redo the dynamic hyperlink by scratch since there is no way to edit the path in the mxd file?
I was hoping to edited the path in the mxd to directory which contain all the pdfs and shapefiles used for the project.
The path for the dynamic hyperlink is not the same for all the mxd file.
It would be so easy to edited the mxd path for Dynamic Hyperlinks.
Daniel
