Is it possible to change the path of dynamic hyperlinks?
I hyperlink a shapefile with 100 polygons with each polygon contain 2 or more hyperlink per polygon to pdfs using the dynamic hyperlink through the identity tool.
I moved the folder containing the pdfs that were used to hyperlink to our network so the mxd containing the shapefile file would view by other people.
My question is it possible to update path to the network containing the pdf folder in your mxd file?
I guess the Hyperlink base under the Map Document Properties will not change the path to the pdf folder?
Daniel
