Is Image Server Extension needed?
1044
07-21-2011 01:51 PM
RandyKreuziger
I understand mosaic datasets can read in ISDEF files.   Now that Mosaic Datasets are here is their any reason for the Image Server Extension?
MelanieHarlow
There is no need to purchase the Image extension and install the stand-alone version to create and publish ISCDefs. However, to publish a mosaic dataset you need the the Image extension for ArcGIS Server. If this sounds confusing, see ArcGIS Server Image extension version 10 versus 9.3.
The online content states:
*NOTE: ArcGIS 10 is the last release of the stand-alone ArcGIS Image Server product. The image service definition (.ISDef) has been replaced by an improved geodatabase data model�??the mosaic dataset�??which can be published as an image service using the ArcGIS Server Image extension.
To migrate, see: Migrating an .ISDef to a mosaic dataset.
