Inverted terrain features
1275
06-12-2013 05:00 AM
by Anonymous User
Not applicable
Original User: jimcousins
Greetings,
I have some aerial imagery with the shadowing causing terrain features to be inverted - hills look like depressions and gullies look like ridges (see attachment Aerial unchanged.jpg). Is there any way to alter this so it looks correct without rotating the data frame (what is should look like is attachment Aerial rotated.jpg).
by Anonymous User
Not applicable
Original User: sarajase
Appears to be scanning error/artifact.
Perhaps nothing much could be done about it other than to rescan
By some chance it is not a product of some digital mapping camera (such as MS Vexcel or Leica ADS80), isn't it?
Thanks
JimCousins
You misunderstand. This is not an artifact from scanning, it is an optical illusion created by the direction of the shadows on the ground during the image capture from the airplane. the two photos show the same extents and the same groundsurface, but the features that are raised appear sunken and the features that are sunken appear raised. When you rotate the photo 180 degrees, the features invert and what was sunken appears raised and what was raised appears sunken.
My question is what method exists (if any) that will produce the inversion of features without rotating the image.
Regards,
Jim
