Import AIXM 4.5 To AIS
1121
10-27-2016 08:10 AM
GlenOlli
I am trying to complete the ArcGIS for Aviation: Charting course : "Introduction to ArcGIS for Aviation: Charting", and when i try to do the Import AIXM 4.5 To AIS i am failing to complete the process.
The end of the error message is this:
"FME API version of module 'GEODATABASE_SDE' matches current internal version (3.7 20150407)
An ArcGIS license is already checked out. The product checked out is 'Advanced'
Installed ArcGIS version is '10.4'
Connection made to server 'GDITIRANA_MSSQLEXPRESS' for dataset 'Database Servers\GDITIRANA_MSSQLEXPRESS.gds\ASP_PD (VERSION:DBO.DEFAULT)' (transactional version 'DBO.Student') using instance 'sde:sqlserver:GDITIRANA\MSSQLEXPRESS' and user ID 'Glen'
ArcSDE release: '7.0'. Underlying database: 'SQL Server'
All errors encountered while writing features will be ignored as directed by the '_IGNORE_FAILED_FEATURE_ENTRY' keyword
Failed to add domain 'UOM_Dist_Ver' to the workspace
A fatal error has occurred. Check the logfile above for details
... Last line repeated 2 times ...
Bridge failed to output feature on tag `PYOUTPUT'
PythonFactory failed to process feature
Closing the Geodatabase writer
Feature output statistics for `GEODATABASE_SDE' writer using keyword `GEODATABASE_SDE_2':
Features Written
Total Features Written 0
FME Session Duration: 1 minute 28.9 seconds. (CPU: 30.7s user, 19.1s system)
END - ProcessID: 8704, peak process memory usage: 528336 kB, current process memory usage: 478684 kB
Program Terminating
Translation FAILED.
Tool execution failed.
Failed to execute (ImportAIXM45ToAIS).
Failed at Thu Oct 27 16:33:50 2016 (Elapsed Time: 1 minutes 35 seconds)"
Can anybody please help me?
Thanks in advance
