Image Service from Mosaic Layer
973
01-20-2018 06:00 AM
by Anonymous User
Not applicable
I understand you can make an image service from a Mosaic Layer.
I have a mosaic dataset with four rasters. I can DQ each raster into a separate layer in ArcMap, but you can't make an image service from a layer in ArcMap.
I hate to ask such a basic question, but the documentation didn't describe how you'd use a mosaic layer to make an image service, only that it could be done.
If I could just get a small nudge in the right direction, I would really appreciate it.
Thank you,
Randy McGregor
JayantaPoddar
So you need to create a Mosaic Layer and Save it as a Layer file (*.lyr). Make Mosaic Layer—Help | ArcGIS Desktop
To make your layer permanent, right-click the layer in the table of contents and click Save As Layer File
From ArcCatalog Window, right-click the Mosaic Layer and Share as Image Service Publishing image services—Documentation | ArcGIS Enterprise
Hope this helps!!!
Think Location
by Anonymous User
Not applicable
Thank you! Very helpful
ModyBuchbinder
Just right click your mosaic and select Share as Image service
