Image Analysis Window: Grayed Out Display Tools
5177
07-09-2014 12:28 PM
EricBladh
I'm using the Image Analysis Window for the first time.  When I bring in a single band from landsat and open up the Image Analysis window all the tools are "Grayed Out".  I have the Raster Checked in the Image Analysis Window.  The Raster is a .tif file type.  I tried to see if the Image Analysis window used a specific file type, but it doesn't specify.  Any comments would be welcome.  Thanks!
JimCousins
You need to check the box adjacent to the filename, and then select / highlight the filename
