Ii have two shape file, one is parcel data and the other is impervious surfaces within parcel. Parcel data has unique parcel id and if i want the same id to be in impervious surface file how can i do it?
5866
7
02-18-2015 07:58 AM
ritisharma
I have two shape file, one is parcel data and the other is impervious surfaces within parcel. Parcel data has unique parcel id and if i want the same id to be in impervious surface file how can i do it?
TimWitt2
You could use a spatial joint. ArcGIS Desktop
TimWitt2
ritisharma
but how do i join if i don't have common id on both files.
ChrisDonohue__GISP
The Spatial Join works by joining information based on location, which is different than an attribute join (an attribute join is typically based on a common ID field).  So don't worry about not having a common ID.
Chris Donohue, GISP
ChrisDonohue__GISP
Quick thought - a couple of processes come to mind that would probably work:
1.  Do a "Spatial Join":
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
2.  Alternatively, run an Identity (Geoprocessing tool):
Chris Donohue, GISP
ChrisDonohue__GISP
This may help in seeing how it is done:
GIS Tutorial: How to perform a spatial join in ArcMap - YouTube
Chris Donohue, GISP
ritisharma
Problem solved !! Thank you Chris and Tim. You guys are awesome.
ChrisDonohue__GISP
Be sure to mark Tim Witts' post as the correct solution.  Both so he gets credit for it (he beat me to it) and so others who search on this topic see that an answer was found.
Chris Donohue, GISP
