I am a data owner. When I clicked administrator geodatabase on data connection and tried to disconnect user locks however it stated "insufficient permission". How can I fix it? I need to disconnect users. I also have access to SQL Server Management Studio
3135
07-02-2017 02:46 PM
AlexP_
I am a data owner. When I clicked administrator geodatabase on data connection and tried to disconnect user locks however it stated "insufficient permission". How can I fix it? I need to disconnect users. I also have access to SQL Server Management Studio.
Asrujit_SenGupta
Being the Data Owner is not enough to disconnect users from a geodatabase. Check this link for more details:
Manage connections in SQL Server—Help | ArcGIS Desktop
To disconnect users from a geodatabase in Microsoft SQL Server, the geodatabase administrator may need additional privileges.
  • The geodatabase administrator (sde) in an sde-schema geodatabase requires VIEW DEFINITION privileges on the database to see the list of connected users and must be a member of the processadmin fixed server role to disconnect users.
  • If the geodatabase administrator of a dbo-schema geodatabase is the database owner, the geodatabase administrator must be added to the processadmin fixed server role to disconnect users.
No additional privileges are required for the geodatabase administrator in a dbo-schema geodatabase if the geodatabase administrator is a member of the sysadmin fixed server role.
Asrujit_SenGupta
