How to restore default dropdown menus
2308
11-21-2012 11:45 PM
AlexPiel
I recently (somehow) deleted key elements of my dropdwon toolbar, e.g. "File", etc. such that currently, the first dropdown is "Insert." I've spent much too long in Customize trying to restore the default settings to no avail.
Can someone advise on either how to recover these dropdown menus, or else to restore the default dropdown menus in ArcMap 10?
Many thanks in advance,
Alex
MarcinGasior
Try to rename/delete Normal.mxt template which is located in (or something similar):
C:\Users\<username>\AppData\Roaming\ESRI\Desktop10.0\ArcMap\Templates\Normal.mxt
When you start ArcMap next time, it will create a new Normal.mxt and all your customizations will be lost.
AlexPiel
That did it, fantastic!
Apologies for not writing sooner. THANK. YOU!
Alex
