How to resize polygon with no distortion.
3130
10-15-2013 09:35 PM
tae_junjung
[ATTACH=CONFIG]28357[/ATTACH]
as above image,
i want resize polygon with no distortion.
and, it is the best way using scale unit(like a x10, x1/4 etc..)
how can i do this work??
please, tell me a solution! ^^
JohnSobetzer
Honored Contributor
You could convert it to a graphic, then right click on it and resize it in different ways in Properties - Size & Position while preserving the aspect ratio.  Then convert the graphic back to a shape.
RobertBorchert
Honored Contributor
Use the Scale tool.
If you go to customization type in scale in the commands area it is in the Editor Category
This will resize your polygons without changing the shape.
Just make sure you don't mess with the geographic center point.  it is the anchor.
as above image,
tae_junjung
thank you
i had converted to graphic. but now, i want to know how to convert the grphic back to a shape....^^;;
JohnSobetzer
Honored Contributor
Drawing toolbar - Drawing dropdown list - Convert graphics to features.
tae_junjung
thanks a lot! i have solved the problem with your comment ^^
