How to repair pseudo nodes on polygons
2052
07-02-2018 05:31 AM
BartekBlatkiewicz
Hello, i have a problem with missing verticies on polygon shared borders. Is there any tool to fix this for many features?
DanPatterson_Retired
You didn't mention anything about topology... so I will leave that aside
You could try a...
Check Geometry
and if errors are found
Repair Geometry
or just try it on its own.
Alternately a
Dissolve
with an
Unsplit line
might make things go away
BartekBlatkiewicz
I tried reapir geometry but it didn't solve the case. Dissolve with unsplit lines in cases like below:
Did something like this:
So no one approach will manage all cases... to be expected I suppose
BartekBlatkiewicz
It can be done with integrate tool, but at first i didn't notice that the gap between polygons was larger than used tollerance. (Tollerance was set to 0,001 while gap was 0,003)
