How to preserve circular arcs when exporting to DGW?
1651
02-12-2017 12:16 PM
LR
When exporting shapes to DWG, ArcMap converts my arcs to straight line segments. Is there a way to stop this?
DanPatterson_Retired
sounds like there is more than a simple export...what properties are in your file?
LR
I've already read that up and down, added fields, tried using a DWG as seed, nada. I only had limited success so far with the data interop extension which produces slightly less unsighty curves by creating more vertices.
