I'm trying to export raster datasets from a raster catalog and for the exported raster datasets to have the names that they have within the catalog rather than being named after the raster catalog itself. I set up a model to iterate through the rasters in the raster catalog and export them using 'Raster To Other Format'. However when I run this model the output rasters are named after the raster catalog with incremental numbering so I get '[catalogname]_1', '[catalogname]_2' etc.
I included a Parse Path to try and get the raster dataset name and assign it to the output, but I can only get it to point at 'Raster.OBJECTID=1'.
'Raster To Other Format' doesn't allow me to specify an output file name so I can't use '%Value%' even if the Parse Path was working as I intended.
Any alternatives or workarounds would be very welcome!
Thanks.
