How to keep mxd customization upon ArcMap upgrade
2323
07-27-2017 06:23 AM
LouToscano
I am upgrading ArcMap from 10.2 to 10.4 and want to keep my toolbars and customizations, etc.
JayantaPoddar
You could test the following.
Keep a backup of C:\Users\<UserName>\AppData\Roaming\ESRI\Desktop10.2.
Replacing the Normal.mxt template after the new install might work.
Think Location
LouToscano
I would copy the current Normal.mxt at the path, below; then after updating ArcMap, I could replace the Normal.mxt that came with the update with the saved one.?
Louis L. Toscano Jr.
GIS Technician, Compliance and Technology
Brick Utilities
1551 Hwy. 88 West
Brick, New Jersey 08724-2399
732-458-7000 ext. 4242
[email protected]<mailto:[email protected]>
JayantaPoddar
Yes. You can replace the Normal.mxt
I would suggest you to keep a backup of C:\Users\<UserName>\AppData\Roaming\ESRI\Desktop10.2. You might need the connections of ArcCatalog as well.
Think Location
LouToscano
Thanx for all your help.
Regards,
Brick Utilities
1551 Hwy. 88 West
LouToscano
Thank you very much for your help!
Lou
