how to get the lat and long from feature table in Oracle DB
1911
06-14-2024 05:40 AM
DRae
Hi I heard that in MS SQL, we can do the following
select shape, shape.STX as LONG, shape.STY as LAT from sde.fc
If my Geodatabase is in Oracle, and how can I get the STX and STY from the shape column. I tried the above and it return
ORA-00904: "SHAPE"."STX": invalid identifier
00904. 00000 - "%s: invalid identifier"
George_Thompson
Esri Notable Contributor
DRae
Thanks. I am able to do as below
select sde.st_x(shape) from fc
VinceAngelo
Esri Esteemed Contributor
Note that you should never store user data in the SDE schema, so the "from sde.fc" part is a problem. Best practice is to create a new login to own spatial data (and a new tablespace to store the data for that login).  Using the SDE login for this is akin to using SYSTEM or DBO for noodling, or web surfing the dark net as administrator -- It's not likely to end well.
- V
