How to get/set path to unmanaged raster dataset?
1374
12-10-2010 03:32 AM
SteveStanton
How do I access the path to the image files in an unmanaged raster catalog? And how can I change it if the files have been moved?
I'm aware of the ExportRasterCatalogPaths and RepairRasterCatalogPaths in ESRI.ArcGIS.DataManagementTools, but it seems like a lot of jumping through hoops, and documentation of GP tools leaves something to be desired.
I had hoped to do it like this:
string GetPath(IRasterValue rv)
[INDENT]    IDatasetName dsn = (rv.RasterDatasetName as IDatasetName);
    IWorkspaceName wsn = dsn.WorkspaceName;
    return wsn.PathName;
[/INDENT]}
But that just gives me the path of the enclosing geodatabase. Looking at the files in the GDB folder, I see things like *.CatItemsByPhysicalName.atx, which I'm guessing contains the information I'm after. Is there a way to get inside these?
I'm working with ArcGIS Engine 10.
RobertBerger
Greetings,
Yes these Geoprocessing tools are the ones to use to change the paths. I am sure you can do something similar through code since the paths have to be stored in the catalog table somewhere. I don't know exactly how to access these fields in the table or how to edit them through code though.
Robert
