I want to geocode bike routes on the map. Now I have created an excel sheet containing information about primary road, cross intersection 1 (start point) and cross intersection 2(end point). There are about 300 records need to be geocoded, and I really don't want to draw them manually...
Attempts have been made to create route layers by using Network Analyst, but I don't have that extension available on my computer. Is there any other way to geocode lines?
I really appreciate it if someone could shed some light on this question.
Somehow, you'll need to select the all the segments of a given street between the two points, right?
Sharing a piece of code that was helpful for me to tackle this project:
#Extract centerline between two other centerline
import arcpy, string, os, sys, datetime
centerline=r"Your Feature Dataset Path"
outFC=r"Feature Dataset Path"
if arcpy.Exists(outFC):
arcpy.Delete_management(outFC)
arcpy.CreateFeatureclass_management(r"Your database", "MoratoriumStreets", "POLYLINE", "", "", "", centerline)
arcpy.AddField_management(outFC, "ROWNUMBER", "SHORT", "", "", "", "Row ID")
arcpy.AddField_management(outFC, "DESCRIPTION", "TEXT", "", "", "100", "Description")
arcpy.AddField_management(outFC, "COMPLETIONDATE", "DATE", "", "", "", "Completion Date")
arcpy.AddField_management(outFC, "EXPIRATIONDATE", "DATE", "", "", "", "Expiration Date")
cwd=sys.path[0] #looks in the directory for the module?
xlFile=os.path.join(cwd,"MoratoriumList.xlsx")
arcpy.ExcelToTable_conversion(xlFile,r"in_memory\Streets","Streets")
arcpy.MakeTableView_management(r"in_memory\Streets","Streets_View") #creates a temp table view
arcpy.MakeFeatureLayer_management(centerline,"centerline_Lyr") #Creates a temp feature layer from input
ctr=1
cursor=arcpy.SearchCursor("Streets_View") #Used to establish a read-only cursor for iteration and extraction of value
row=cursor.next()
while row:
row_ID = row.getValue("RowNumber")
StreetSegment = row.getValue("StreetSegment")
CompletionDate = row.getValue("DateOfCompletion")
CompletionDate_formatted = "\'" + CompletionDate.strftime("%d") + "/" + CompletionDate.strftime("%m") + "/" + CompletionDate.strftime("%Y") + "\'"
ExpirationDate = row.getValue("Expiration")
ExpirationDate_formatted = "\'" + ExpirationDate.strftime("%d") + "/" + ExpirationDate.strftime("%m") + "/" + ExpirationDate.strftime("%Y") + "\'"
qry = "FULLNAME = \'" + StreetSegment + "\'"
arcpy.SelectLayerByAttribute_management("centerline_Lyr", "NEW_SELECTION", qry)
if str(arcpy.GetCount_management("centerline_Lyr")) != '0':
arcpy.Dissolve_management("centerline_Lyr", r"in_memory\centerline_dis_" + str(ctr), "FULLNAME", "", "SINGLE_PART")
from_Street = row.getValue("FromStreet")
from_qry = "FULLNAME = \'" + from_Street + "\'"
arcpy.SelectLayerByAttribute_management("centerline_Lyr", "NEW_SELECTION", from_qry)
arcpy.FeatureVerticesToPoints_management("centerline_Lyr", r"in_memory\From_Pts_" + str(ctr), "BOTH_ENDS")
to_Street = row.getValue("ToStreet")
to_qry = "FULLNAME = \'" + to_Street + "\'"
arcpy.SelectLayerByAttribute_management("centerline_Lyr", "NEW_SELECTION", to_qry)
arcpy.FeatureVerticesToPoints_management("centerline_Lyr", r"in_memory\To_Pts_" + str(ctr), "BOTH_ENDS")
from_to_qry = "FULLNAME = \'" + from_Street + "\' OR FULLNAME = \'" + to_Street + "\'"
arcpy.SelectLayerByAttribute_management("centerline_Lyr", "NEW_SELECTION", from_to_qry)
arcpy.FeatureVerticesToPoints_management("centerline_Lyr", r"in_memory\From_To_Pts_" + str(ctr), "BOTH_ENDS")
arcpy.SplitLineAtPoint_management(r"in_memory\centerline_dis_" + str(ctr), r"in_memory\From_To_Pts_" + str(ctr), r"in_memory\centerline_dis_split_" + str(ctr), "0 Feet")
arcpy.MakeFeatureLayer_management(r"in_memory\centerline_dis_split_" + str(ctr), "centerline_dis_split_Lyr_" + str(ctr))
arcpy.SelectLayerByLocation_management("centerline_dis_split_Lyr_" + str(ctr), "INTERSECT", r"in_memory\From_Pts_" + str(ctr), "", "NEW_SELECTION")
arcpy.SelectLayerByLocation_management("centerline_dis_split_Lyr_" + str(ctr), "INTERSECT", r"in_memory\To_Pts_" + str(ctr), "", "SUBSET_SELECTION")
arcpy.GeneratePointsAlongLines_management("centerline_dis_split_Lyr_" + str(ctr), r"in_memory\centerline_dis_split_pts" + str(ctr), "PERCENTAGE", Percentage=7)
arcpy.SelectLayerByLocation_management("centerline_Lyr", "INTERSECT", r"in_memory\centerline_dis_split_pts" + str(ctr), "0.05 Feet", "NEW_SELECTION")
Description = "\'" + (StreetSegment + "_" + from_Street + "_" + to_Street).replace(" ", "_") + "\'"
print "Copying the line segments.."
arcpy.CopyFeatures_management("centerline_Lyr", r"in_memory\Selection_" + str(ctr))
arcpy.AddField_management(r"in_memory\Selection_" + str(ctr), "ROWNUMBER", "SHORT", "", "", "", "Row ID")
arcpy.AddField_management(r"in_memory\Selection_" + str(ctr), "DESCRIPTION", "TEXT", "", "", "100", "Description")
arcpy.AddField_management(r"in_memory\Selection_" + str(ctr), "COMPLETIONDATE", "DATE", "", "", "100", "Completion Date")
arcpy.AddField_management(r"in_memory\Selection_" + str(ctr), "EXPIRATIONDATE", "DATE", "", "", "100", "Expiration Date")
arcpy.CalculateField_management(r"in_memory\Selection_" + str(ctr), "ROWNUMBER", row_ID, "PYTHON_9.3")
arcpy.CalculateField_management(r"in_memory\Selection_" + str(ctr), "DESCRIPTION", Description, "PYTHON_9.3")
arcpy.CalculateField_management(r"in_memory\Selection_" + str(ctr), "COMPLETIONDATE", CompletionDate_formatted, "PYTHON_9.3")
arcpy.CalculateField_management(r"in_memory\Selection_" + str(ctr), "EXPIRATIONDATE", ExpirationDate_formatted, "PYTHON_9.3")
arcpy.Append_management(r"in_memory\Selection_" + str(ctr), outFC, "NO_TEST")
else:
print "Cannot find " + qry
ctr+= 1
row = cursor.next()
del cursor, row
