How to export geodatabase to MS Excel or Access?
14476
8
03-09-2020 05:23 PM
MereKelly
I had a fairly simple geodatabase sent to me. I am not able to see the file's full contents unless I open it in Arc GIS Pro. The easiest way for me to run computations with it would be to export to Excel or Access. The only export tool I send to find involves export the metadata to xml. That is not what I need. Is there a way to do this?
MereKelly
Thank you, this is great! Is there something similar for Access?
DanPatterson_Retired
Access isn't supported in Pro or Map, you will have to do that elsewhere
HamedFarzin
Mere Kelly‌ You can use both ArcGIS Pro and Arc map to do this: Please use instruction in the links below:
ArcGIS Pro:  Export tables—ArcGIS Pro | Documentation
ArcMap: How To: Export an attribute table from ArcMap to Microsoft Excel
Hope this helps!
RobertBorchert
Honored Contributor
Create a personal geodatabase.
Copy all the features from file geodatabase to the personal.
A Personal Geodatabase is a MS Access Database
MereKelly
Hello, thanks for replying. What command (or series of commands) can I use in Arc GIS Pro to do that? I don't see that as an export option for tables.
Table To Table—Conversion toolbox | Documentation
but dbf, csv or txt are the output options
and from here
Frequently asked questions—ArcGIS Pro | Documentation
Can I use personal geodatabases (.mdb) as data sources for ArcGIS Pro?
No. Personal geodatabases are not supported in ArcGIS Pro, so you cannot use personal geodatabase datasets as inputs for geoprocessing tools or create those datasets as outputs. File geodatabases are fully supported and are the default workspaces for ArcGIS Pro projects.
RobertBorchert
Honored Contributor
Personal Geodatabase are not recognized by Pro. You would have to use ArcCatalog.
You can also right click on any feature in pro and select
Data >  Export Tables
